Bearing dowel pins, "Watch for tight fit" |
brer |
Apr 22 2007, 01:26 AM
Advanced Member Group: Members Posts: 2,555 Joined: 10-March 05 From: san diego Member No.: 3,736 Region Association: None |
The FSM has a note to watch for tight or "perfect" fit in the bearing dowel pins.
I'm wondering how loosy or tighty these little buggers are best at? Mine move a little in the three large mains and kinda loosy in the case at the nose bearing. So are we needing a specific fit here or what? (IMG:style_emoticons/default/huh.gif) fit in the bearing halves (mahle) is not snug at all. I bolted the halves together today without the cam gear and the crank seems nice and smooth. The rod for #3 was plastiguaged and came up at .0015 or so, but its bloody impossible to keep the bloomin' rod still while torqueing it. So I'm not sure its totally accurate. After installing the rod on the crank it would fall on its own weight but kind of quick, not smooth and slow. After I check the deck height I'm thinking maybe i'll take that guy off and fiddle. Cam is snug, I think the axial play is to little.... >.001 Adams Ave. Roots and Blues is happenning down the street, so I had some swinging bluegrass to listen to all day. (IMG:style_emoticons/default/aktion035.gif) |
craig downs |
Apr 22 2007, 04:29 PM
Senior Member Group: Members Posts: 769 Joined: 25-November 05 From: mira loma ca. Member No.: 5,189 Region Association: Southern California |
The dowel pins should slip down in the holes of the case without any side movement
Lo-Fi Version | Time is now: 22nd June 2024 - 08:02 PM |
