mrhurtalot |
VRRRRRRROOOOOOOOOM! ![]() ![]() Group: Members Posts: 323 Joined: 5-October 06 From: Yukon, Oklahoma Member No.: 6,996 ![]() |
(IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif)
holy begeezus, seems things dont want to work out for me. short vers. cv bolt not a torx driver stripped... (IMG:style_emoticons/default/confused24.gif) SEARS! bolt remover head snapped off. ........ ....... two weeks later still stuck. tried various things, pb blaster, reverse bits, tap die set. drill nothing seems to work. if you are local and you happen to help me maybe you can get some free (IMG:style_emoticons/default/beer.gif) (IMG:style_emoticons/default/beerchug.gif) Attached thumbnail(s) ![]() ![]() |
John |
member? what's a member? ![]() ![]() ![]() ![]() Group: Members Posts: 3,393 Joined: 30-January 04 From: Evansville, IN (SIRPCA) Member No.: 1,615 Region Association: None ![]() |
Like Mark suggested, I would grind it off to get the CV joint off. You could then use a locking type pliers to remove the bolt. if it is still stuck, you can get a real cheap output flange for the trans.
Lo-Fi Version | Time is now: 25th June 2024 - 08:22 PM |
