Center Console wiring, Help me!!! |
malaga_red75 |
Apr 24 2007, 10:14 PM
'74 2.5L N/A Subie Group: Members Posts: 454 Joined: 5-March 06 From: Menlo Park, CA Member No.: 5,674 Region Association: None |
Hey, so I just got my new to me center console....(Thanks Sean!!!!)
So, first thing i did was pull the gauges from the panel and test them. They all work!! clock still ticks, volt still works and the temp worked on accident as my dad and i touched the green wire to a power and the temp needle sweeped up.....anywyas. I found some wires under the carpet, above the center tube, are these the wires for the gauges?? heres a picture. Thanks in advance!! Attached image(s) |
Dave_Darling |
Apr 25 2007, 12:25 AM
914 Idiot Group: Members Posts: 15,000 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
Under the battery somewhere should be a single-wire plastic box connector, similar to the ones in your picture above. The wire connects there to another green/black wire that runs across the front of the engine under the engine tin, and winds up going into the "taco plate" at the left-front corner of the bottom of the motor.
--DD |
Lo-Fi Version | Time is now: 25th June 2024 - 09:44 PM |
