> while the engine is out...how to safely remove the, rear trunk torsion springs in 20 minutes
rhodyguy
post Apr 29 2007, 01:03 PM
tools required:
grinder
a couple of old bath towls
10mm deep well 1/4" drive socket, ratchet and long exstension (disregard the ones pictured)
2 zip ties
a 35"stick
1. slip socket w/ext on the pass bar end @ the roller. you may have to persuade it a bit.
2. press the exstension down and lever the end sideways off the roller.
3. prop trunk open, and secure it at the top. see picture.
4. climb into the eng compartment, fold the towels so they're thick. pull the springs toward you a bit and stuff the towels on both sides of the point you are going to cut. if the towel goes in easy, refold and repack. it should be a jammed in fit.
5. make 1 cut at a time! you may want to repack the towels after the first cut. cut other spring.
6. take your 10mm setup and remove the 4 clips the that secured the springs to the body. throw scrap on garage floor for pictures. DONE.
k
Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image
rhodyguy
post Apr 29 2007, 09:35 PM
"starts trying to tear it off". (IMG:style_emoticons/default/dry.gif)
i would never buy and cut steel, stand at a grinder, and devote the time it took to make that tool that i would need exactly 2 times in my life. different strokes... (IMG:style_emoticons/default/blink.gif)
james makes very nice products. (IMG:style_emoticons/default/thumb3d.gif)
i hope it was hemp rope ron. (IMG:style_emoticons/default/unsure.gif)
i really wasn't looking to start a debate about the springs. i was hoping to provide a quick, effective, and safe way of removing them. sorry to disappoint. btw... the 20 minutes included collecting the items needed and taking pictures. (IMG:style_emoticons/default/headbang.gif)
k
- Lo-Fi Version Time is now: 6th January 2025 - 09:30 PM
