V8 Conversion Completed, 1975 1.8L to Chevy 283 - Added Dyno Test Pg. 1 |
nick mironov |
Jan 15 2006, 12:58 PM
nickm Group: Members Posts: 204 Joined: 12-June 05 From: San Francisco, CA Member No.: 4,264 |
My conversion took approximately 5 months of work to get the engine in and get the car on the road. Another 18 months for further work and improvements. Thanks very much to the 914 Club Forum and those who posted their conversion information and to those who responded to my questions, and special thanks to the club members who attended the V8 conversion meeting in Pleasanton in September 05 and shared their valuable knowledge with me.
If anyone is interested in seeing the car, I live in the Richmond District of San Francisco. Project Specs: 1975 1.8L 914 Renegade conversion kit Chevy 283 Vortec heads Compcam 260H New cam bearings 0.060 cylinder overbore New rods and pistons (9.5:1 compression ratio) New main and rod bearings Replaced all gaskets and freeze plugs New high volume oil pump MSD Billet HEI distributor Holley 4 barrel carburetor Treated miscl rust with OSPHO and Por 15 paint Herculiner truck bed liner in front and engine compartments 911 19mm master brake cylinder upgrade BMW 320i front caliper upgrade to start with, M-caliper upgrade using hubs by Mueller Stainless steel flex brake hose upgrade Replaced rear brake proportioning valve with TEE. Rebuilt rear brake calipers Pedal cluster bushings upgrade to brass (from existing plastic) Replaced transmission shifter bushings Replaced transmission seals Weltmeister short-shifter WEVO transmission mounts 9” Kevlar clutch New Bilstein rear shocks and bellows/boots. Electric fuel pump – Carter CRT-P4070 5 psi, 72 gph New / custom throttle cable HP mini-starter 2-gauge wire to starter Ron Davis Radiator with two 13”diameter SPAL fans (Renegade set-up) Renegade bypass thermostat system VDO Water temperature gauge VDO Oil pressure gauge VDO Oil temperature gauge (original) Tachometer upgrade by bigmarkdesign Oil Cooler Center console Rear trunk strut conversion kit – Camp 914 Magnaflow dual-in dual-out muffler Body work and re-paint Power mirrors from Honda del Sol Rear wing from Toyota MR-2 Interior seat and backpad kits by Autos International Carpets by Morph Towbar for flat towing with integral wiring harness 16" 4-lug Superlight wheels from Pack Racing Products BF Goodrich G-Force Sport 205/55/16. The dyno tests were done this 8/24/2008 at the Thunderhill dyno. At max rpm of about 6,250 the dynamometer showed a speed of 153 mph. On the track we got it up to about 125 mph. However, it threw a water pump belt a couple of times. I think that there is too much flex in the Renegade water pump mount, so I need to reinforce it. At rear wheels: 263 ft-lb torque, 241 hp. Engine: Assuming a 15% loss through the transmission, the engine would have about: 302 ft-lb torque, 277 hp. Maybe more if the test was done on a motor dyno stand without water pump, alternator, and muffler. Without air filter: With and without air filter: |
nick mironov |
May 4 2007, 08:24 PM
I changed the Renegade provided rubber hoses for steel pipes, custom bent to the contour of the bottom of the car, and welded hose nozzles on the ends. The return pipe and hoses are 1-1/4" and the supply pipe and hoses are 1" - Renegade recommended sizes:
Attached image(s) |
Lo-Fi Version | Time is now: 22nd November 2024 - 10:20 PM |
