914orRust |
Newbie ![]() Group: Members Posts: 16 Joined: 20-August 05 From: St. Paul, MN Member No.: 4,623 ![]() |
Ok. About 2 years ago, I purchased a 74 teener. Since then I've had the engine rebuilt and replaced more parts than I dare list all the while knowing that there is some serious hell hole/rocker panel rust to address. The car isn't sagging yet but I know this is an issue that must be addressed.
To make matters worse... I live in Minnesota and I have no welding skills of my own. Thus far I've contacted a couple random body shops and I've received responses ranging from "no way I'm touching that" to "you need a top off restoration". I know I can't afford a top off restoration. So, my question to the list is... do I throw in the towel and sell to someone that has welding experience? Is there a solution that does not require a full restoration? Is that option available in Minnesota? Thank you in advance for any wisdom you may have with this issue. ~Marc |
lotus_65 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,608 Joined: 21-March 05 From: minneapolis, mn Member No.: 3,795 Region Association: Northstar Region ![]() |
The good thing about all that is if you decide to fix it, it's reasonable to expect it will never be ignored again, leading to a much longer life than expected.
But I still think that if you have the means, a new roller infused with the gear you have already invested in is in order. Then put this one on a longer-term resurrection plan, learn to weld, consider upgrades, etc. That way, for maybe a a thousand bucks (and your time), your actually driving this summer instead of being frustrated with a project you didn't expect. paul |
Lo-Fi Version | Time is now: 26th June 2024 - 02:03 AM |
