Is there a differance in cooling fans ?, Two different looking fans |
JBart |
May 6 2007, 05:56 PM
UNDER CONSTRUTION Group: Members Posts: 110 Joined: 9-October 06 From: Wildomar Ca. Member No.: 7,019 |
I need some help here I took my fan off to replace the oil cooler seals and the bolts are different along with the looks of the fan itself . The first picture is the fan off of my 72'. The second fan is off ? it came with a box o parts. The part # of the second fan is 021 119 113 the fan off my car has no part #.
One of the 12pt. bolts on my car was stripped so I either need to find the same 12pt. bolts or can I switch the fan out so I can use regular hex head bolts either way is fine by me I just need to find the 12pt. bolts I didn't see any at PP Thanks, jbart Also there is a picture of the bolt from my car. Attached image(s) |
TheCabinetmaker |
May 6 2007, 06:34 PM
I drive my car everyday Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
regular bolt. Correct length is important. not sure about hardness of bolt.
Lo-Fi Version | Time is now: 26th June 2024 - 05:54 AM |
