rhodyguy |
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,117 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch ![]() |
the engine would turn (by hand) prior to the install. initially it turned fine when trying to start it. never did light off. made a wierd noise or 2, now, it won't turn at all. full charge on bat. starter just clicks. plugs out, in gear, pass side tire chocked, i can not turn the engine with the dr side tire at all. like it's hitting something. i have 0 answers or ideas. just about at the end and ready to take a huge loss on everything. debating whether to pull the engine, and just roll the car out and tarp it. words can not express....
k |
echocanyons |
Advanced Member ![]() ![]() ![]() ![]() Group: Benefactors Posts: 2,094 Joined: 24-December 02 From: Bay Area, CA Member No.: 7 Region Association: Central California ![]() ![]() ![]() |
QUOTE But I am not going to ask you if you TESTED the starter again. (did you?) (IMG:style_emoticons/default/agree.gif) Test the starter while out of the car. Other things that can make the starter not turn are low or partially discharged battery and ground issues. Once you rule out the starter and the battery you can assume it is your engine or flywheel. (I know that still doesn't explain not being able to turn the wheels, but this leads me to believe that it isn't your starter too.) |
Lo-Fi Version | Time is now: 28th June 2024 - 05:38 PM |
