i have to pull the engine, locked up |
rhodyguy |
May 7 2007, 03:05 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,188 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
the engine would turn (by hand) prior to the install. initially it turned fine when trying to start it. never did light off. made a wierd noise or 2, now, it won't turn at all. full charge on bat. starter just clicks. plugs out, in gear, pass side tire chocked, i can not turn the engine with the dr side tire at all. like it's hitting something. i have 0 answers or ideas. just about at the end and ready to take a huge loss on everything. debating whether to pull the engine, and just roll the car out and tarp it. words can not express....
k |
rhodyguy |
May 8 2007, 11:13 AM
i took this before the old engine pull. i'll have to try the battry charger to energize the starter. red charger lead to the to the spade term for the yellow wire and the black chargr wire to nut with the wire that secures the wire that goes to the starter body. all it does is hum. are these the correct test points for the starter out of the car?
weird. the old setup workd just fine when i put the car away for its winters sleep. how the starter could go bad just sitting is beyond me. but then, quite a few things are. k Attached image(s) |
Lo-Fi Version | Time is now: 20th September 2024 - 05:04 PM |
