Clutch Disk Thickness, Anyone measure a new one?? |
tracks914 |
May 9 2007, 08:28 PM
Canadian Member Group: Benefactors Posts: 2,083 Joined: 15-January 03 From: Timmins, Ontario, Canada Member No.: 153 Region Association: None |
I need to replace my clutch, it's getting out of adjustment.
I have two other ones here that I can put in but I don't know what kind of life they will have. They look good but without the thickness I don't know if I will be wasting my time putting one in. If one has better than 50% life left in it, for the 2000 miles a year I drive it, I think I will put it in. Anyone have the thickness of a new one? BTW '72 1.7 but I don't think it matters. Thanks |
tracks914 |
May 10 2007, 04:45 PM
This disk measures 9mm but there is some deflection in the metal plates between the 2 disk halves.(all the waty around) If I compress the disk it measures 8.47mm all the way around. Is this normal?
Justinp71 |
May 10 2007, 06:14 PM
Senior Member Group: Members Posts: 1,588 Joined: 11-October 04 From: Sacramento, CA Member No.: 2,922 Region Association: None |
This disk measures 9mm but there is some deflection in the metal plates between the 2 disk halves.(all the waty around) If I compress the disk it measures 8.47mm all the way around. Is this normal? ???? My brand new one was the same way, something like 9.8mm and 9.5mm compressed. That was the $68 6-spring, 4-spring replacement disk. |
Lo-Fi Version | Time is now: 24th June 2024 - 07:28 AM |
