eric914 |
Member ![]() ![]() Group: Members Posts: 381 Joined: 28-January 04 From: Waynesville OH Member No.: 1,613 Region Association: Upper MidWest ![]() ![]() |
I am doing a suby swap (in the future) and have the Kennedy suby adaptor with a stage 2 pressure plate, stock disk, and through out bearing Kennedy makes.
For the summer though I got a 1.8L air-cooled motor and have swapped the transmission over to it. I can't seem to get enough travel on the throw out arm as it is currently set up. The Kennedy instructions call for the removal of the washer under the pivot ball when installing on the Suby motor. I am starting to think I should have reinstalled this washer when I swapped the transmission back to the air-cooled motor. Any thoughts? I hate to think I need to pull the motor so close to having things done. If I need to add this washer back, does anyone know how thick it should be? Attached image(s) ![]() ![]() |
dflesburg |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,720 Joined: 6-April 04 From: Warm and Cheerful Centerville Ohio Member No.: 1,896 Region Association: None ![]() |
Call them, I wanted to make sure I was putting my stuff on the 3.2 correctly, I called them, they were very helpful. They do know what they are doing...
Lo-Fi Version | Time is now: 24th June 2024 - 11:58 PM |
