Can't adjust my clutch, kennedy stage 2 PP and stock disk |
eric914 |
May 11 2007, 08:39 AM
Member Group: Members Posts: 381 Joined: 28-January 04 From: Waynesville OH Member No.: 1,613 Region Association: Upper MidWest |
I am doing a suby swap (in the future) and have the Kennedy suby adaptor with a stage 2 pressure plate, stock disk, and through out bearing Kennedy makes.
For the summer though I got a 1.8L air-cooled motor and have swapped the transmission over to it. I can't seem to get enough travel on the throw out arm as it is currently set up. The Kennedy instructions call for the removal of the washer under the pivot ball when installing on the Suby motor. I am starting to think I should have reinstalled this washer when I swapped the transmission back to the air-cooled motor. Any thoughts? I hate to think I need to pull the motor so close to having things done. If I need to add this washer back, does anyone know how thick it should be? Attached image(s) |
eric914 |
May 11 2007, 09:46 AM
Thanks for the advice. I will call then when they open.
As a side note to the Cap'n - If you don't deal with Kennedy, were do you source uprated pressure plates from? If there is a better source I would use them in the future. |
Lo-Fi Version | Time is now: 26th September 2024 - 11:46 AM |
