Bartlett 914 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,216 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest ![]() |
Stevo asked to see some pictures of the tunnel I have. Here they are for all to see.
Attached image(s) ![]() ![]() |
will |
licensed to kill ![]() ![]() Group: Members Posts: 272 Joined: 14-December 05 From: rancho cucamonga, california Member No.: 5,276 ![]() |
just wondering how people deal with rust in the tunnel?
Bartlett 914 |
just wondering how people deal with rust in the tunnel? My car was one of the worst cases. Rear window leak and it sat for a long time. The tunnel and in between the firewalls must have had had a lot of standing water in them. My solution was drastic. I replaced both firewalls, front and rear pan, and I also replaced all the tubes in the tunnel. I am still worried about the inside of the longs. The outsides are fine. Inside? It would be nice if there was a tunnel floor patch. I suppose It could have been cut out / repaired and welded back in place. The accelerator tube is very close to the bottom. I cut into it in several places removing the floor pan. If you are considering this, be careful. |
will |
just wondering how people deal with rust in the tunnel? My car was one of the worst cases. Rear window leak and it sat for a long time. The tunnel and in between the firewalls must have had had a lot of standing water in them. My solution was drastic. I replaced both firewalls, front and rear pan, and I also replaced all the tubes in the tunnel. I am still worried about the inside of the longs. The outsides are fine. Inside? It would be nice if there was a tunnel floor patch. I suppose It could have been cut out / repaired and welded back in place. The accelerator tube is very close to the bottom. I cut into it in several places removing the floor pan. If you are considering this, be careful. If I use a rust inhibitor spray and spray it as much as I can in the tunnel, will I damage anything inside the tunnel? (i.e. fuel lines?) What if i just pour POR-15 and just let it spread as far as it can go? any thoughts? |
Lo-Fi Version | Time is now: 29th June 2024 - 06:20 PM |
