akellym |
Eyes Of The Deep Battle ![]() ![]() ![]() Group: Members Posts: 597 Joined: 25-July 04 From: Annandale, MN Member No.: 2,395 Region Association: Northstar Region ![]() |
Okay, so last week the car starting running crappy. checked the fuel pressure, was jumping around then dropped to 0(I have carbs running at 3lbs). So yesterday I installed my brand new back up pump. I was tunning the carbs, everything was going great. After 20mins the car start running crappy again, look at the fuel pressure it was doing the same thing again. Car died, fuel pump wasn't making any noise, checked and it was flaming hot! I have a primary and secondary fuel filter both are clean. Called Mallory they said it must be a bad pump, send it back. Fine, so overnight a new pump install it, this time checking it often. It starts getting hot, what the flip! I can hear the pump changing in pitch, so I think must be elec. I'm getting 13.5v at the pump. My volt reg is rather hot so I put in a new one, now I'm getting 14.2v at the pump. Still getting hot, change the relay( it was hot also) still getting hot!
some pics of the set up. Any suggestions? Attached image(s) ![]() ![]() |
akellym |
just tried running a ground direct, was using a harness ground wire. Still no change.
Lo-Fi Version | Time is now: 24th June 2024 - 07:03 AM |
