catch tanks, puke tanks, oil retireval, recirculation, for a 4 banger, pics would be great along with descriptions |
DanT |
May 12 2007, 01:00 AM
Going back to the Dark Side! Group: Members Posts: 4,300 Joined: 4-October 04 From: Auburn, CA Member No.: 2,880 Region Association: None |
of what you did and why you did it. (IMG:style_emoticons/default/smile.gif)
I am running stock d-jet but would like to see your solutions for that set up and carbed set ups. wanting to get some ideas before I start fabbing something up. |
Jake Raby |
May 12 2007, 08:12 AM
Engine Surgeon Group: Members Posts: 9,398 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States |
JPB, you seem confused... Dan is asking about crankcase breather options and why they are needed.....
The reason why crankcase ventilation is so impprtant is because the pressure that stays pent up in the case that is leaking past rings and exhaust valves will harnass HP and will also make for a very leaky engine that has its oil pressure fed from the crankcase.... Thats the main reason why some people have oil leaks that are not curable no matter what they seal the engine with. Inadequate crankcase ventilation is one of the most overlooked items associated with the TIV engine- the hotter the engine runs the more it expands and the more crankcase pressure will exist. |
JPB |
May 13 2007, 06:39 AM
The Crimson Rocket smiles in your general direction. Group: Members Posts: 2,927 Joined: 12-November 05 From: Tapmahamock, Va. Member No.: 5,107 |
JPB, you seem confused... Dan is asking about crankcase breather options and why they are needed..... The reason why crankcase ventilation is so impprtant is because the pressure that stays pent up in the case that is leaking past rings and exhaust valves will harnass HP and will also make for a very leaky engine that has its oil pressure fed from the crankcase.... Thats the main reason why some people have oil leaks that are not curable no matter what they seal the engine with. Inadequate crankcase ventilation is one of the most overlooked items associated with the TIV engine- the hotter the engine runs the more it expands and the more crankcase pressure will exist. OOps, miss read. Me silly (IMG:style_emoticons/default/av-943.gif) |
Lo-Fi Version | Time is now: 24th September 2024 - 01:04 PM |
