> Backpad and Seat Re-Upholstery, From Autos International Kits
nick mironov
post May 14 2007, 10:07 PM
nickm
This shows how to re-upholster late model backpad and seats using pre-made kits.
This thread should nicely complement the excellent How to Restore Headrest, Tutorial with Pictures thread in the classics forum.
My kits came from Autos International - ask for Auggie. Nice guy, very helpful, did extra research for me, sent samples, and used custom fabric and perforation.
I also found kits at World Upholstry, but they did not want to deal with other than vinyl or leather fabric, and I wanterd the perforated suede. I think that there are other upholstery kits available as well.
Basic costs are about $200 a seat and $200 for the backpad. Mine were a little more because of the perforated "suede" material from Miami Corp that I elected to use.
At first I thought that I would try to sew the upholstery myself, using the existing pieces as templates. I finally decided against it and I am very glad that I did not attempt to sew.
The only problem that I had was that the seat headrest fabric fit too loosely. Autos International would have fixed it, but I took care of it myself by re-stitching some of the seams. I am sure that they would have done it better than I did, but I did not want to send them the headrests and wait to get them back. If you choose Autos International, I recommend that you send them your headrests for proper fitting.
After shooting a number of pictures, I found that my camera was starting to act up and finally failed. Many of the pictures were unfortunately not salvageable, so I only chose the best ones, and the presentation is not as detailed as I had hoped it would be.
Mt 914 is a V8 conversion with 16" 4-lug Superlight wheels.
Carpet kits are by Morph.
Make sure that you have a good staple gun and get 2 large cans of spray-on adhesive (I used 3M Super 77) and two tubes of rubber cement (I used Barge Cement)
Very important: Remove the fabric from only one piece or seat at a time, leaving the other intact for you to reference the details during the re-assembly process.
Finished Interior:
nick mironov
post May 14 2007, 10:32 PM
nickm
Now you are ready to install the new upholstery.
Start by laying the seam into the heel of the contour and then overlay the bead you salvaged over the seam. Start stapling form the top and stretch the seam away from the top as you staple from top to bottom - very important.
The first picture shows the foam pad just laying there on the left. Its final position is to the right of the bead. The second picture shows the foam pad glued in place. The installed foam pad must cover the bead, otherwise the fabric will not be in contact with the foam and will have air pockets.
nick mironov   Backpad and Seat Re-Upholstery   May 14 2007, 10:07 PM
nick mironov   Backpad re-upholstering: First remove the seats. ...   May 14 2007, 10:16 PM
nick mironov   Remove all of the staples form the back and then p...   May 14 2007, 10:22 PM
nick mironov   Repair any damage to the backing board. I used fib...   May 14 2007, 10:25 PM
nick mironov   Now you are ready to install the new upholstery. ...   May 14 2007, 10:32 PM
nick mironov   Fill any tears and gouges in the padding with clea...   May 14 2007, 10:37 PM
nick mironov   This is where the camera failed, so I did not get ...   May 14 2007, 10:45 PM
nick mironov   This is one finished side. Repeat the process on t...   May 14 2007, 10:49 PM
nick mironov   Next work on the center pad. This is very easy com...   May 14 2007, 10:54 PM
nick mironov   Reassemble the three pieces - two side pieces and ...   May 14 2007, 10:57 PM
partwerks   Reassemble the three pieces - two side pieces and...   Jul 27 2021, 07:08 PM
nick mironov   The seats are next. Disassemble only one at a tim...   May 14 2007, 11:01 PM
nick mironov   Remove two screws on the back of the headrest that...   May 14 2007, 11:04 PM
nick mironov   Remove the backpad. Note the three hooks at the ba...   May 14 2007, 11:09 PM
nick mironov   This picture shows the backside of the backpad. No...   May 14 2007, 11:09 PM
nick mironov   Now remove the seat rails using a hex key on the a...   May 14 2007, 11:13 PM
nick mironov   Remove the seat cover fabric. Note that it is held...   May 14 2007, 11:16 PM
nick mironov   Pull the wire beads out from the side pockets. I p...   May 14 2007, 11:18 PM
nick mironov   Disassemble the backpad. Very carefully, using you...   May 14 2007, 11:22 PM
nick mironov   You are now ready to start re-upholstering the sea...   May 14 2007, 11:29 PM
nick mironov   Work the fabric by stretching the wrinkles out.   May 14 2007, 11:30 PM
nick mironov   Spray glue on the botton of the seat and on the fa...   May 14 2007, 11:31 PM
nick mironov   Glue the "shoulders", stretching them as...   May 14 2007, 11:35 PM
nick mironov   Back to the backpad. Install the new cover over t...   May 14 2007, 11:38 PM
nick mironov   Install the backpad over the seat. Hook the headr...   May 14 2007, 11:41 PM
nick mironov   Re-attach the interior screws to hold the headrest...   May 14 2007, 11:43 PM
nick mironov   Spray adhesive and glue in the backing into the co...   May 14 2007, 11:46 PM
nick mironov   Finally the seat cushions... These are the easies...   May 14 2007, 11:52 PM
nick mironov   And the finished product again...   May 14 2007, 11:53 PM
MrKona   Let me be the first to say... NICE JOB! :bee...   May 15 2007, 12:42 AM
markb   Yes indeed, nicely done. You might go back & f...   May 15 2007, 12:55 AM
Jerry   Wow, very nice!!!! I think this...   May 15 2007, 07:57 AM
johannes   GREAT JOB !... I vote for the classics too. A...   May 15 2007, 11:07 AM
9146986   I'll 2nd or 3rd the vote on making this a Clas...   May 15 2007, 01:46 PM
Rotary'14   :agree: Great pics, good information. Insant cl...   May 15 2007, 05:36 PM
Joe Owensby   Nice job. thanks for sharing with us. Joe   May 15 2007, 06:50 PM
SGB   love that blue fabric.   May 15 2007, 10:49 PM
bigkensteele   I can't get enough of these kinds of threads. ...   May 16 2007, 12:35 AM
smj   Great job Nick, thanks for putting this together. ...   May 16 2007, 05:15 PM
Gint   That looks fantastic Nick!   May 16 2007, 07:29 AM
Eric_Shea   This will be a "Classic" for sure. Th...   May 16 2007, 05:25 PM
johannes   This thread should be in the "classic"   Aug 19 2007, 05:01 AM
OU812   This thread should be in the "classic" ...   Jul 22 2016, 05:59 PM
Halfnelson   Just want to add a belated thanks for this thread ...   Jan 29 2020, 09:56 AM
76-914   Just want to add a belated thanks for this thread...   Jan 29 2020, 10:05 AM
dr914@autoatlanta.com   autos international does fabulous work   Jan 29 2020, 10:28 AM
dstudeba   autos international does fabulous work The orig...   Dec 8 2023, 06:04 PM
Mikey914   If you need the tabs we make them. In stainless an...   Dec 9 2023, 11:23 AM
11 User(s) are reading this topic (11 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 3rd April 2025 - 09:29 PM
