Phoenix-MN |
Senior Member ![]() ![]() ![]() Group: Members Posts: 927 Joined: 23-January 04 From: ST. Bonifacius,MN Member No.: 1,590 ![]() |
![]() I was working on getting my fuel tank, fuel pump, and lines intalled today and I have been trying to figure out how to adapt the tank fittings to AN. After getting the tank on the bench and removing the stock fittings and tubes it looked like a 1/4npt pipe thread fitting might fit in the opening of the stock fitting. I dug out my taps and low and behold the 1/4npt tap threaded the hole in the stock fitting quite nicely. Could it realy be this easy? What am I missing? Anyone else done it this way? |
Phoenix-MN |
andys,
The id. of the stock fittings is a little larger than 7/16", I didn't measure the exact size. I think the threads that are cut will be fine, they are just a little deeper on the tap so the fitting screws in a little bit more, but far from bottoming out. The final test will be to put some fitting on with caps, fill the tank and see if it leaks before putting it in the car. Attached thumbnail(s) ![]() |
Lo-Fi Version | Time is now: 25th June 2024 - 06:11 PM |
