Head temp sensor, Installing |
whitey |
May 27 2007, 11:53 PM
Member Group: Members Posts: 146 Joined: 8-February 07 From: Coto de Caza Member No.: 7,508 |
I need to install a new head temp sensor II. It seems that you can't remove the rubber bushing in the engine tin. Is there a way to remove it or do you just have to force it out like the other bushings? Do I need to remove the top tin to expose the sensor to replace it?
Thanks, Dave |
2-OH! |
May 28 2007, 10:25 AM
Senior Member Group: Members Posts: 552 Joined: 17-October 03 From: Santa Clarita, Kalifornication Member No.: 1,253 |
Come back to us if the car runs like crap after you replace it...
I have a 73, 1.7 and by the book, I should not need the resistor between the sensor and the ECU...But, by actual experience, my car would not run until it reaches 180 degrees... Solved the problem by putting a resistor in between the the new sensor and the brain... Yes, it was the correct part number for the 1.7... 2-OH! |
Lo-Fi Version | Time is now: 31st October 2024 - 08:22 PM |
