shifter bushings, larger bushings |
Tom |
Jun 2 2007, 11:56 AM
Advanced Member Group: Members Posts: 2,139 Joined: 21-August 05 From: Port Orchard, WA 98367 Member No.: 4,626 Region Association: None |
After putting new bushings in the trans bracket for the shifter rod, I still had a lot of slop. Taking it apart and measuring found the following. New Bushings are 0.600 inside dia and 0.815 outside dia. My bracket hole for the bushing is 0.830 and my rod is 0.588. Made another bushing for the rod that is slightly larger. Will get back later to let all know how it turns out.
Also made a couple of bushings for the yoke at the fire wall. Press fit and hone to fit pin. This tightened up that area very well. I used a white delrin material to make the bushings out of as this material is supposed to be good for this type of application. Later, Tom |
Dr Evil |
Jun 2 2007, 12:04 PM
Send me your transmission! Group: Members Posts: 23,002 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
Very cool, is the delrin you are using more plyable than the OE part so it is easier to install?
Lo-Fi Version | Time is now: 20th June 2024 - 11:39 PM |
