orange914 |
http://5starmediaworks.com/index.html ![]() ![]() ![]() ![]() Group: Members Posts: 3,371 Joined: 26-March 05 From: Ceres, California Member No.: 3,818 Region Association: Northern California ![]() |
anything out there worth looking into that is reasonably priced that gives any horse power gain? (IMG:style_emoticons/default/confused24.gif)
mike |
anthony |
2270 club ![]() ![]() ![]() ![]() Group: Benefactors Posts: 3,107 Joined: 1-February 03 From: SF Bay Area, CA Member No.: 218 ![]() ![]() |
IMHO, there are pretty much no easy/cheap/simple upgrades for the motor that produce significant hp. The best bang for the buck is probably exhaust - 1.7L SSI heat exchangers can still be found relatively cheaply. You can add a Bursch exhaust to that.
The best bang for the buck is to build a 2056 with a decent cam and exhaust. You'll get a solid 115hp and will be able to scratch the tires in 2nd gear. From a stock 1.7 it's a huge hp, and more importantly torque boost. It's even a big torque boost over a stock 2L. You can build a 2056 of those for around $2500. If you go with EFI you can use a different cam and probably squeeze another 10hp out of it. But unless you can roll your own megasquirt, that will cost $$$. Beyond the 2056, incremental boosts in HP cost a small fortune IMO. |
Lo-Fi Version | Time is now: 28th June 2024 - 02:10 PM |
