> no turn signals and brake lights, where do I start?
jfort
post Jun 17 2007, 11:33 AM
to try to solve no turn signal problem, I replaced light switch and flasher relay, checked fuses, cleaned all connections and put in new bulbs, cleaned but did not replace turn signal switch. now i realize i have no brake lights either. all other lights and emergency flashers work. i think those two circuits are not getting power. i have to find my color wiring diagram, but in the meantime, can someone tell me where to start? they say, "check grounds." i have and know how to use a meter, but i don't know how to check grounds. help
seejay5
post Jun 17 2007, 12:14 PM
Fawk it, use hand signals.
jfort
post Jun 18 2007, 07:53 PM
thanks, 904svo. i thought i had checked fuses. but, sure enough, #9 was burnt. i had run a wire from the right rear to a middle LED brake light. it rubbed through and was touching the body. fixed not only the brake lights, but also the turn signals. IM SO HAPPY!
- Lo-Fi Version Time is now: 6th January 2025 - 08:24 PM
