Need a little help.... Flywheel Bolts won't budge, Any tips?? bigger Braker Bar??? |
hwgunner |
Jun 18 2007, 11:42 PM
914 Parts @ Discount Prices 800.321.5432 Group: Members Posts: 1,714 Joined: 11-November 04 From: Santa Maria, Ca Member No.: 3,095 Region Association: None |
OK, so I need a little help. For all the cars I have pulled apart, I am pretty much a maverick and just start pulling things off without reguard for order or proper form. I am trying to change that and pretty much hit a brick wall right off the bat. I can not get the flywheel bolts (17mm) to budge. I have not hit them with the impact wrench but have hit them with penetrating oil. Any good tips. I know these get torqued down to 120lbs or something but now how do I get them off. I want to get the flywheel off so that I can mount it on my engine stand with the steel 'ring' which brings up the second question. If you ae facing the trans end of the engine, which side does the ring go on so that you cansplit the case and get to all the good stuff in side. I know this is long but your help is appreciated. Here is a pic.
Attached thumbnail(s) |
sww914 |
Jun 19 2007, 12:01 AM
Advanced Member Group: Members Posts: 2,439 Joined: 4-June 06 Member No.: 6,146 Region Association: None |
Impact will work better than torque. Put your ratchet on there and HIT it with a hammer, or use your impact driver or impact gun.
IIRC, you build (and install the mount on) the R side of the engine as installed in a 914, the L side as installed in a VW or 911. I may make it down to SM later this week, I'll call you of I head that way. |
hwgunner |
Jun 19 2007, 12:05 AM
Thanks, I will try the hammer. The one thing that I did find is that the heads of the bolts are so shallow the socket does not like to 'grab'. I will try though.
just call me and I will do everything I can to meet you. thanks Impact will work better than torque. Put your ratchet on there and HIT it with a hammer, or use your impact driver or impact gun. IIRC, you build (and install the mount on) the R side of the engine as installed in a 914, the L side as installed in a VW or 911. I may make it down to SM later this week, I'll call you of I head that way. |
Lo-Fi Version | Time is now: 25th June 2024 - 08:31 PM |
