hwgunner |
914 Parts @ Discount Prices 800.321.5432 ![]() ![]() ![]() Group: Members Posts: 1,714 Joined: 11-November 04 From: Santa Maria, Ca Member No.: 3,095 Region Association: None ![]() |
OK, so I need a little help. For all the cars I have pulled apart, I am pretty much a maverick and just start pulling things off without reguard for order or proper form. I am trying to change that and pretty much hit a brick wall right off the bat. I can not get the flywheel bolts (17mm) to budge. I have not hit them with the impact wrench but have hit them with penetrating oil. Any good tips. I know these get torqued down to 120lbs or something but now how do I get them off. I want to get the flywheel off so that I can mount it on my engine stand with the steel 'ring' which brings up the second question. If you ae facing the trans end of the engine, which side does the ring go on so that you cansplit the case and get to all the good stuff in side. I know this is long but your help is appreciated. Here is a pic.
Attached thumbnail(s) ![]() |
rhodyguy |
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,115 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch ![]() |
go to a vw parts retailer and get one of these. i think i paid about $10. break out the impact gun. you'll spend more time waiting for the compressor to charge with air than you will removing the bolts.
k Attached image(s) ![]() |
hwgunner |
go to a vw parts retailer and get one of these. i think i paid about $10. break out the impact gun. you'll spend more time waiting for the compressor to charge with air than you will removing the bolts. k Actually I am not haveing a problem with that at the moment. The motor is not turning over. I was just not able to get good grip on the bolts and get enough pressure on them to loosen them. I am going to hit them with an impact when I get home. |
Lo-Fi Version | Time is now: 25th June 2024 - 08:37 PM |
