customstarr |
King of the Nighttime World ![]() ![]() Group: Members Posts: 116 Joined: 13-February 07 From: Waterford, Michigan - Home of Waterford Hills Road Racing Member No.: 7,531 ![]() |
My car still idles like pure crap. Very inconsistent - high to low surging, super low, rich... you name it, this car's idle is ALL OVER THE PLACE. It's never the same condition. The car runs like a raped ape and goes good, but the idle sux complete ass. I used to be able to get some idle adjustment at the TB screw (I don't have the ECM screw), but today I set the fuel pressure correctly (was at 42 PSI) and now I have no control over the idle mix/speed. Maybe someone in the past tried to cover the problem by cranking up the fuel pressure. I'm not seeing the super rich condition now, but like I said... no control.
I've been through everything: replaced/fixed wiring, new ignition system, battery, cables, checked all the standard fare + what I've listed below, etc. This is getting ridiculous. What I've replaced thus far: 1. Ignition: Coil, Cap, Rotor, Points, Condenser, Plugs, Wires (all Bosch except plugs). 2. Fuel/D-Jet: TS1, Fuel Filter, Vacuum Lines. What I've checked, adjusted to spec, or tested to be good: 1. Ignition: Points, Timing, Trigger Points. 2. Fuel/D-Jet: MPS, TS2, Fuel Pressure Reg, Cold Start Valve, Aux Air Reg, Injectors, Fuel Lines, Fuel Pump, Throttle Body, Throttle Switch. 3. Engine: Timing, Compression, Valves. |
scotty b |
rust free you say ? ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 16,375 Joined: 7-January 05 From: richmond, Va. Member No.: 3,419 Region Association: None ![]() |
Nope I can't get to the engine for all of the sh*t I have piled up. Maybe somebody else will know what I am talking about.
Pat Garvey |
Do I or don't I...........? ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,899 Joined: 24-March 06 From: SE PA, near Philly Member No.: 5,765 Region Association: North East States ![]() |
Nope I can't get to the engine for all of the sh*t I have piled up. Maybe somebody else will know what I am talking about. Scotty, I know exactly what you're talking about. A white semi-Y shaped connector. The connecting hoses fall off easily with age, hich is why I'm changing mine. ANY air or vacuum leak screws the Djet system up. That's why every 5-7 years you should change every hose - vacuum AND hp fuel (low pressure seems to last longer). Sorry, my 914's UP right now, or I'd lift the prts & pic them. This "Y" piece has no clamps, so it can easilly cause lekage problems. And that means the idle can "hunt", like so many other hoses. Guys, these hoses are readily available (non- high pressure fuel hoses) and they aren't all that expensive. We're talking about "vintage" cars these days - change 'em. |
customstarr |
[quote name='Pat Garvey' date='Jun 21 2007, 06:37 PM' post='914393']
(IMG:style_emoticons/default/cool.gif)--><div class='quotetop'>QUOTE(scotty b @ Jun 19 2007, 06:28 PM) ![]() Nope I can't get to the engine for all of the sh*t I have piled up. Maybe somebody else will know what I am talking about. [/quote] Scotty, I know exactly what you're talking about. A white semi-Y shaped connector. The connecting hoses fall off easily with age, hich is why I'm changing mine. ANY air or vacuum leak screws the Djet system up. That's why every 5-7 years you should change every hose - vacuum AND hp fuel (low pressure seems to last longer). Sorry, my 914's UP right now, or I'd lift the prts & pic them. This "Y" piece has no clamps, so it can easilly cause lekage problems. And that means the idle can "hunt", like so many other hoses. Guys, these hoses are readily available (non- high pressure fuel hoses) and they aren't all that expensive. We're talking about "vintage" cars these days - change 'em. [/quote] All of my lines are good or new. I don't believe that the early DJet cars (mine's a 71) have this Y connector. Vac leak would mean lean - I could use my exhaust as a return fuel line it's so rich. |
Lo-Fi Version | Time is now: 25th June 2024 - 05:13 PM |
