1.7 aftermarket heads, anything out there worth looking into, reasonable price/h.p. gain? |
orange914 |
Jun 16 2007, 09:31 PM
http://5starmediaworks.com/index.html Group: Members Posts: 3,371 Joined: 26-March 05 From: Ceres, California Member No.: 3,818 Region Association: Northern California |
anything out there worth looking into that is reasonably priced that gives any horse power gain? (IMG:style_emoticons/default/confused24.gif)
mike |
G e o r g e |
Jun 21 2007, 10:41 PM
Dr Group: Members Posts: 1,905 Joined: 20-September 05 From: Southern Cal Member No.: 4,832 Region Association: None |
mike why don't you talk to nate (addwestern here, 914-parts ebay ) about one of his running 1.7's example
then purchase those 2 ltr heads from jake ( because if you don't want them i know i would take them at that price), collect the bit's and pieces you need for the rebuild and build one hot little 1911. but change your cam. |
orange914 |
Jun 22 2007, 05:21 PM
mike why don't you talk to nate (addwestern here, 914-parts ebay ) about one of his running 1.7's example then purchase those 2 ltr heads from jake ( because if you don't want them i know i would take them at that price), collect the bit's and pieces you need for the rebuild and build one hot little 1911. but change your cam. what grind out there work well with stock d-jet (not changing that). i'm leaning toward 1.8 new casting heads and 96mm. i think i'm pushing d-jet perameters, not sure how large valve will do. i should have answer next week (desision on 2.0 heads) |
Mueller |
Jun 22 2007, 05:26 PM
mike why don't you talk to nate (addwestern here, 914-parts ebay ) about one of his running 1.7's example then purchase those 2 ltr heads from jake ( because if you don't want them i know i would take them at that price), collect the bit's and pieces you need for the rebuild and build one hot little 1911. but change your cam. what grind out there work well with stock d-jet (not changing that). i'm leaning toward 1.8 new casting heads and 96mm. i think i'm pushing d-jet perameters, not sure how large valve will do. i should have answer next week (desision on 2.0 heads) no you aren't...there is at least one person here running a 2.3+L with D-Jet ... |
Lo-Fi Version | Time is now: 28th June 2024 - 02:25 PM |
