orange914 |
http://5starmediaworks.com/index.html ![]() ![]() ![]() ![]() Group: Members Posts: 3,371 Joined: 26-March 05 From: Ceres, California Member No.: 3,818 Region Association: Northern California ![]() |
anything out there worth looking into that is reasonably priced that gives any horse power gain? (IMG:style_emoticons/default/confused24.gif)
mike |
G e o r g e |
Dr ![]() ![]() ![]() Group: Members Posts: 1,905 Joined: 20-September 05 From: Southern Cal Member No.: 4,832 Region Association: None ![]() ![]() |
mike why don't you talk to nate (addwestern here, 914-parts ebay ) about one of his running 1.7's example
then purchase those 2 ltr heads from jake ( because if you don't want them i know i would take them at that price), collect the bit's and pieces you need for the rebuild and build one hot little 1911. but change your cam. |
orange914 |
mike why don't you talk to nate (addwestern here, 914-parts ebay ) about one of his running 1.7's example then purchase those 2 ltr heads from jake ( because if you don't want them i know i would take them at that price), collect the bit's and pieces you need for the rebuild and build one hot little 1911. but change your cam. what grind out there work well with stock d-jet (not changing that). i'm leaning toward 1.8 new casting heads and 96mm. i think i'm pushing d-jet perameters, not sure how large valve will do. i should have answer next week (desision on 2.0 heads) |
Mueller |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,146 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None ![]() ![]() |
mike why don't you talk to nate (addwestern here, 914-parts ebay ) about one of his running 1.7's example then purchase those 2 ltr heads from jake ( because if you don't want them i know i would take them at that price), collect the bit's and pieces you need for the rebuild and build one hot little 1911. but change your cam. what grind out there work well with stock d-jet (not changing that). i'm leaning toward 1.8 new casting heads and 96mm. i think i'm pushing d-jet perameters, not sure how large valve will do. i should have answer next week (desision on 2.0 heads) no you aren't...there is at least one person here running a 2.3+L with D-Jet ... |
orange914 |
mike why don't you talk to nate (addwestern here, 914-parts ebay ) about one of his running 1.7's example then purchase those 2 ltr heads from jake ( because if you don't want them i know i would take them at that price), collect the bit's and pieces you need for the rebuild and build one hot little 1911. but change your cam. what grind out there work well with stock d-jet (not changing that). i'm leaning toward 1.8 new casting heads and 96mm. i think i'm pushing d-jet perameters, not sure how large valve will do. i should have answer next week (desision on 2.0 heads) no you aren't...there is at least one person here running a 2.3+L with D-Jet ... o.k. if d-jet would handle it (2.0/cam)would the stock 1.7 injectors, intake, plunum work? i'm thinking no. then i'll need to find tin, maybe cht resister and other variables. dont get me wrong i really like the idea but i've only got so much i'm putting into the dropped seat repair. my goal is a quality repair on a limited budjet. the other factor is i'm walking my son kenny (limited mechanical experiance) thru it for his first time. long story short i'm now in a wheelchair and have to instuct him thru it. i dont want to push the whole the thing to complicated. just so i can realistically gauge the 2 seanerios, how much EXTRA $$ would a good guess for the cam, tin, injectors, intake/plunum be? $1200 2.0 heads+ $600+- 96mm +$ other parts =$? i can realistically do new cast 1.8 heads, 96mm pistons, rod bearings and gaskets for apx. $1350 thru auto atlanta. if there was an experianced 914 engine guy out there that would be willing to help us build this, i could be influenced. (IMG:style_emoticons/default/poke.gif) shamless plug... oh and by the way the motor is OUT and on the bench! mike ![]() |
Lo-Fi Version | Time is now: 28th June 2024 - 02:44 PM |
