Hold the Phone... Vol IV, The teener gremlins haven't left! |
BahnBrenner914 |
Jun 22 2007, 02:53 PM
The girl is gone and all I have now is a beat-up teener Group: Members Posts: 301 Joined: 22-May 04 From: Gig Harbor and University Place, WA :: School in Angola, IN :: girlfriend in Sarasota, FL Member No.: 2,094 Region Association: None |
So I took the teener out again this morning (IMG:style_emoticons/default/driving.gif) . I clamped the AAR valve to eliminate it as a problem, cause the car was running ok with the new fuel filter (yesterday). It barely idles and I'm thinking (IMG:style_emoticons/default/idea.gif) , it just has to warm up and it'll run fine if the AAR is still not working, it idles like crap all over town (IMG:style_emoticons/default/dry.gif) , but runs alright when I'm cruising around (IMG:style_emoticons/default/w00t.gif) . A little sluggish when I get to 4K (IMG:style_emoticons/default/yellowsleep[1].gif) , but cruises fine. Well I'm driving around thinking (IMG:style_emoticons/default/idea.gif) I'm ok, and I turn to come back home (about 1.5 miles away) and it gets boggy on me again (IMG:style_emoticons/default/sad.gif) , and the further I go, the worse it gets (IMG:style_emoticons/default/dry.gif) (IMG:style_emoticons/default/dry.gif) . Surging, backfiring like crazy (IMG:style_emoticons/default/ar15.gif) , no power (IMG:style_emoticons/default/yellowsleep[1].gif) (IMG:style_emoticons/default/yellowsleep[1].gif) (IMG:style_emoticons/default/yellowsleep[1].gif) , just barely jerking along at like 5 mph.
Could the fuel filter be plugged up again, cause there's a ton of (IMG:style_emoticons/default/stromberg.gif) in my fuel tank? Someone suggested plug wires, I think I'll replace those when I get some $$$, and check the plugs to, cause who knows what condition they're in now. And of course there's always the vacuum leaks. I'm going to tear out the old air/smog pump crap and put bolts in where the injectors were. And do the propane leak test deal. Any other Ideas? |
SGB |
Jun 23 2007, 08:40 PM
just visiting Group: Members Posts: 4,086 Joined: 8-March 03 From: Huntsville, AL Member No.: 404 Region Association: South East States |
Well it is too late for me because I already did mine, but I wondered if it was a goo idea or not. Even the POR 15 stuff might sluff off one day, I don't know. I think the tank was at least galvanized inside, and ultimately it was good I took mine out as it was rusting from the outside where it sits on a felt pad. I found the easiest way to drain the tank was to disconnect the fuel line back in the engine compartment and use the fuel pump to empty the contents into a gas can, but that was with no return line (carbs) so it might not be a good idea with FI...
Lo-Fi Version | Time is now: 20th October 2024 - 06:55 AM |
