Turn Signal Problems, Won't work with lights on |
Snafu |
Jun 3 2007, 11:36 AM
Member Group: Members Posts: 70 Joined: 29-April 07 From: Beaumont, Texas Member No.: 7,704 Region Association: Southwest Region |
Been having a little problem with the turn signals. I noticed that the dash indicator would light both directionals if I activated the right turn but would work correctly with the left turn. Now....they don't light up at all and the turn signals don't work when I have the headlights on. They work fine with the lights off(even though the dash indicator doesn't) I did have a bulb out in the rear and I checked the connections while I had it apart.
This being my first 914, where should I look next? Anybody ever experiance something like this? Thanks in advance! |
Snafu |
Jun 29 2007, 12:27 PM
Here is a picture of the black wire with the fuse that keeps blowing
Attached image(s) |
904svo |
Jun 29 2007, 12:31 PM
904SVO Group: Members Posts: 1,124 Joined: 17-November 05 From: Woodstock,Georgia Member No.: 5,146 |
Snafu |
Jun 29 2007, 02:33 PM
QUOTE i would suggest that since you just reconnected the assemblies that the problem lies in the connections at the assemblies, specifically that you have attached a brown ground wire to a hot lead!!!! Please look in the "Tech Tips 700" for the wiring hookups. I really think that this will solve your problem. The main thing to consider is that on the front assemblies one of the spades goes all of the way through the connector and the other two are riveted on. Please connect the brown ground lead to the connector that goes all of the way through the connector (31) checked...made sure the brown wire was on 31. QUOTE Remove that BLACK WIRE an see if your lights work, that wire is something that was added trace it out and see where it goes. removed the black wire. goes somewhere in the dash. (IMG:style_emoticons/default/clap56.gif) Got the emergency lights to work but still no turn signals. (IMG:style_emoticons/default/blink.gif) Will update later. |
dr914@autoatlanta.com |
Jun 29 2007, 02:50 PM
914 Guru Group: Members Posts: 8,055 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
QUOTE i would suggest that since you just reconnected the assemblies that the problem lies in the connections at the assemblies, specifically that you have attached a brown ground wire to a hot lead!!!! Please look in the "Tech Tips 700" for the wiring hookups. I really think that this will solve your problem. The main thing to consider is that on the front assemblies one of the spades goes all of the way through the connector and the other two are riveted on. Please connect the brown ground lead to the connector that goes all of the way through the connector (31) checked...made sure the brown wire was on 31. QUOTE Remove that BLACK WIRE an see if your lights work, that wire is something that was added trace it out and see where it goes. removed the black wire. goes somewhere in the dash. (IMG:style_emoticons/default/clap56.gif) Got the emergency lights to work but still no turn signals. (IMG:style_emoticons/default/blink.gif) Will update later. hopefully something has not melted! |
Snafu |
Jun 29 2007, 02:58 PM
Lo-Fi Version | Time is now: 26th September 2024 - 05:29 PM |
