Turn Signal Problems, Won't work with lights on |
Snafu |
Jun 3 2007, 11:36 AM
Member Group: Members Posts: 70 Joined: 29-April 07 From: Beaumont, Texas Member No.: 7,704 Region Association: Southwest Region |
Been having a little problem with the turn signals. I noticed that the dash indicator would light both directionals if I activated the right turn but would work correctly with the left turn. Now....they don't light up at all and the turn signals don't work when I have the headlights on. They work fine with the lights off(even though the dash indicator doesn't) I did have a bulb out in the rear and I checked the connections while I had it apart.
This being my first 914, where should I look next? Anybody ever experiance something like this? Thanks in advance! |
Snafu |
Jul 1 2007, 07:32 PM
OK guys... (IMG:style_emoticons/default/smile.gif) Some success/progress.
Now I'm starting to think the problem may be in the column or the switch mechanism itself. When I have the key in the neutral position and engage the turn signal, I can here it "click" like it wants to work. After fiddling with it I've found that If I put the right amount (slightest) pressure to activate the left turn signal, I can get it to work. I can't do the same when trying to activate the right signal though. Hummm. I feel like I'm really close... (IMG:style_emoticons/default/biggrin.gif) Thoughts? |
904svo |
Jul 1 2007, 08:49 PM
904SVO Group: Members Posts: 1,124 Joined: 17-November 05 From: Woodstock,Georgia Member No.: 5,146 |
OK guys... (IMG:style_emoticons/default/smile.gif) Some success/progress. Now I'm starting to think the problem may be in the column or the switch mechanism itself. When I have the key in the neutral position and engage the turn signal, I can here it "click" like it wants to work. After fiddling with it I've found that If I put the right amount (slightest) pressure to activate the left turn signal, I can get it to work. I can't do the same when trying to activate the right signal though. Hummm. I feel like I'm really close... (IMG:style_emoticons/default/biggrin.gif) Thoughts? Sounds like a bad switch. |
Lo-Fi Version | Time is now: 26th September 2024 - 05:29 PM |
