Dr Evil |
Send me your transmission! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,002 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region ![]() ![]() |
This weekend has been very productive! All of my vehicles are at least turing fuel into noise. Now it is time to make it useful.
I put the fuel pump back in my Benz (it was out because I thought it was problematic). I adjusted the lever that actuates it and it now starts, but it runs rough. -White smoke -Knocks more than a diesel should -Has no power (less then before (IMG:style_emoticons/default/wink.gif) ) I made sure to NOT crank the engine with the pump removed and to keep the pump shaft from rotating so as to keep the orientation of the shafts in both correct. I may be off a little in my adjustment, but adjusting it will be a shitty task and I would like some veriffication that it is out of adjustment from someone more knowledgable than I before I go a bleeding all over the engine again. In summary: - Do the symptoms scream of any particular problem? - any advice? Thanks all! |
DBCooper |
14's in the 13's with ATTITUDE ![]() ![]() ![]() ![]() Group: Members Posts: 3,079 Joined: 25-August 04 From: Dazed and Confused Member No.: 2,618 Region Association: Northern California ![]() |
White smoke? Just for giggles once it's running take off the radiator cap and make sure there aren't any bubbles blowing up through the coolant.
bottomend |
Member ![]() ![]() Group: Members Posts: 180 Joined: 27-August 05 From: LA,Ca Member No.: 4,683 ![]() |
White smoke? Just for giggles once it's running take off the radiator cap and make sure there aren't any bubbles blowing up through the coolant. That would be very bad. It's not a common problem with MB's right? I have a ford 7.3 IDI and it's the song of death for these. |
Lo-Fi Version | Time is now: 26th June 2024 - 11:13 AM |
