> OT: Need some Diesel advise, Oh great collective, bathe me with your knowledge!
Dr Evil
post Jul 2 2007, 12:09 AM
Send me your transmission!
This weekend has been very productive! All of my vehicles are at least turing fuel into noise. Now it is time to make it useful.
I put the fuel pump back in my Benz (it was out because I thought it was problematic). I adjusted the lever that actuates it and it now starts, but it runs rough.
-White smoke
-Knocks more than a diesel should
-Has no power (less then before (IMG:style_emoticons/default/wink.gif) )
I made sure to NOT crank the engine with the pump removed and to keep the pump shaft from rotating so as to keep the orientation of the shafts in both correct. I may be off a little in my adjustment, but adjusting it will be a shitty task and I would like some veriffication that it is out of adjustment from someone more knowledgable than I before I go a bleeding all over the engine again.
In summary:
- Do the symptoms scream of any particular problem?
- any advice?
Thanks all!
Dr Evil
post Jul 4 2007, 02:02 PM
Well genius collective, I cracked all the fuel lines and had Noel crank the engine until fuel came out of all of them. Then hooked them up and experienced a smoother running more powerful running engine (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/smilie_pokal.gif)
Now for the new question: It is smoking thick BLACK smoke very heavily, how do I fix this? Will this go away on its own? Is this due to it not being run for a long time and maybe having previously uncombusted fuel in the chambers from previous failed attempts to start it?
Dr Evil   OT: Need some Diesel advise   Jul 2 2007, 12:09 AM
Mr.C   How long did you run it? Sounds to me like it may...   Jul 2 2007, 12:18 AM
Dr Evil   Realy? Man that would be awsome. Should I just let...   Jul 2 2007, 12:26 AM
brer   bleed the fuel lines. check that the small bleed o...   Jul 2 2007, 12:32 AM
Dr Evil   bleed the fuel lines. check that the small bleed ...   Jul 2 2007, 12:41 AM
Mr.C   Yeah, if it'll stay running let it go until it...   Jul 2 2007, 12:38 AM
Mr.C   Yeah that definately sounds like air in the lines ...   Jul 2 2007, 12:49 AM
Dr Evil   If your right I am gonna give you a beer :D   Jul 2 2007, 12:56 AM
brer   sounds like you need to drive it really hard uphil...   Jul 2 2007, 01:09 AM
Dr Evil   I will flog it arround the complex tomorrow and re...   Jul 2 2007, 01:13 AM
messix   here's my RX for the good Dr! take with la...   Jul 2 2007, 03:05 AM
Paul Illick   White smoke? Just for giggles once it's runni...   Jul 2 2007, 03:20 AM
bottomend   White smoke? Just for giggles once it's runn...   Jul 2 2007, 04:37 AM
bottomend   White smoke is usually the sign of air in the fuel...   Jul 2 2007, 04:36 AM
BiG bOgGs   If you think it is air in your lines, the simple p...   Jul 2 2007, 06:25 AM
WRX914   If you think it is air in your lines, the simple ...   Jul 2 2007, 01:53 PM
BMartin914   White smoke and rough running can also be an indic...   Jul 2 2007, 07:27 AM
Dr Evil   White smoke and rough running can also be an indi...   Jul 2 2007, 09:52 AM
Dr Evil   Oh ya, another tid bit of info that may lean your ...   Jul 2 2007, 10:44 AM
messix   Oh ya, another tid bit of info that may lean your...   Jul 2 2007, 12:17 PM
Dr Evil   "don't run it any more than it takes to...   Jul 2 2007, 12:28 PM
BiG bOgGs   Sorry Dr., I should have said to crack the lines o...   Jul 2 2007, 12:20 PM
BiG bOgGs   He means not to run it until you are ready to pu...   Jul 2 2007, 12:32 PM
Brian Mifsud   Have you checked the fuel pump timing? I just sol...   Jul 2 2007, 12:37 PM
BiG bOgGs   Another thought. If you do the purge and still fi...   Jul 2 2007, 12:38 PM
brer   Actually, the germans would rather you unscrew the...   Jul 2 2007, 01:08 PM
Dr Evil   Actually, the germans would rather you unscrew th...   Jul 2 2007, 01:45 PM
Brian Mifsud   The crowbar method I believe was an american in...   Jul 2 2007, 03:32 PM
bd1308   If you find that the diesel stuff becomes too much...   Jul 2 2007, 05:04 PM
Dr Evil   If you find that the diesel stuff becomes too muc...   Jul 3 2007, 12:34 AM
Dr Evil   Well genius collective, I cracked all the fuel lin...   Jul 4 2007, 02:02 PM
Mr.C   I would run it for a while and see. Can you adjus...   Jul 4 2007, 02:59 PM
Dr Evil   As far as I know, the fuel can not be adjusted as ...   Jul 4 2007, 03:04 PM
messix   i don't know much about benz but there should ...   Jul 4 2007, 04:15 PM
Dr Evil   Its MFI, I cant find any such adjustment in the li...   Jul 4 2007, 11:27 PM
13 User(s) are reading this topic (13 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 6th January 2025 - 06:25 PM
