BahnBrenner914 |
The girl is gone and all I have now is a beat-up teener ![]() ![]() Group: Members Posts: 301 Joined: 22-May 04 From: Gig Harbor and University Place, WA :: School in Angola, IN :: girlfriend in Sarasota, FL Member No.: 2,094 Region Association: None ![]() |
Took out the gas tank and it indeed is full of (IMG:style_emoticons/default/stromberg.gif) . I'll let the pics tell the rest:
Attached image(s) ![]() |
jk76.914 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 809 Joined: 12-April 05 From: Massachusetts Member No.: 3,925 Region Association: North East States ![]() |
I did the POR-15 route. Here's the before and after- (I've posted this before) I wasn't dealing with as much as you are. The POR treatment took care of the surface rust before the final sealing.
ammason |
Member ![]() ![]() Group: Members Posts: 88 Joined: 14-March 05 From: Sunny Honolulu Member No.: 3,758 Region Association: Hawaii ![]() |
I did the POR-15 route. Here's the before and after- (I've posted this before) I wasn't dealing with as much as you are. The POR treatment took care of the surface rust before the final sealing. I have to say that I'm a HUGE fan of the POR-15 system. My only advice is that you use nits/bits of iron or something ferromagnetic when you shake it around (or did you already do this? I might have missed it). The only reason is that when I treated an old tank I skipped over that part and used rocks and couldn't get them out after the thing had been cleaned. The good part is that the sealant is strong and thick and it just made the rocks a permanent part of the inside of the gas tank. I patched several holes that were more than 1/2" in diameter with JB-Weld after treating the inside of a tank, coated the inside, and then drove 5000 miles, before hitting a big rock (this was in the Caddy and the tank was exposed under the trunk of the car) and knocking another hole. That stuff works fantastically - and if you're worried about bare metal, just make sure you use their whole system, including the finish coat - it's like rustoleum and will keep the rust from coming back... |
Lo-Fi Version | Time is now: 25th June 2024 - 10:19 PM |
