Pulled the tank Vol V, Total Rust Bucket |
BahnBrenner914 |
Jul 2 2007, 10:06 PM
The girl is gone and all I have now is a beat-up teener Group: Members Posts: 301 Joined: 22-May 04 From: Gig Harbor and University Place, WA :: School in Angola, IN :: girlfriend in Sarasota, FL Member No.: 2,094 Region Association: None |
Took out the gas tank and it indeed is full of (IMG:style_emoticons/default/stromberg.gif) . I'll let the pics tell the rest:
Attached image(s) |
McMark |
Jul 4 2007, 01:27 PM
Watch out for reusing the sock. The flash aluminum washer/base is a sealing point. Use some fuel safe, non-drying sealant there or you will have a slow leak that will stink up the car as well as being mildly unsafe.
Danny_Ocean |
Jul 4 2007, 04:02 PM
Member Group: Members Posts: 170 Joined: 27-June 07 From: Fort Lauderdale, FL Member No.: 7,846 Region Association: South East States |
Watch out for reusing the sock. The flash aluminum washer/base is a sealing point. Use some fuel safe, non-drying sealant there or you will have a slow leak that will stink up the car as well as being mildly unsafe. Can you provide more detail? Are you saying the base of the sock seals the inlet tube to the tank? What does/did the factory use to seal this? (Sorry for the hijack, but I'm about to embark on the same project. |
McMark |
Jul 5 2007, 02:01 AM
Watch out for reusing the sock. The flash aluminum washer/base is a sealing point. Use some fuel safe, non-drying sealant there or you will have a slow leak that will stink up the car as well as being mildly unsafe. Can you provide more detail? Are you saying the base of the sock seals the inlet tube to the tank? What does/did the factory use to seal this? (Sorry for the hijack, but I'm about to embark on the same project. You've got it. Basically the base of the sock is a crush washer (single use). It deforms when you install it. So the factory didn't have to use sealant, and you don't either if you use a new one. |
Lo-Fi Version | Time is now: 25th June 2024 - 10:25 PM |
