neo914-6 |
neo life ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,086 Joined: 16-January 03 From: Willow Glen (San Jose) Member No.: 159 ![]() |
Introduction: Complete instructions to install the rear needle bearings (let me know if I've missed anything)
These bearings were designed and manufactured by Mike Mueller and sold direct or through Tarret Engineering. He ceased production so they are currently NLA. 736conver also made them in '05 but are NLA. SRS (Shine Racing) had the same design and sold their last bearing sets in '06 with no plans to reproduce. If you are interested in buying needle bearings, contact McMark to get on the pre-sale list. Below are some discussions or comparisons with other bushings to help you decide whether these bearings are right for you. They are a relatively expensive option and require more maintenance than bushings. They are used in most race cars. Which bushings: PolyGraph, Bronze, needle bearing,, or Delrin? Suspension Bushings, Needle vs. Bronze control arm bushings Roller bearing/poly rear bushing Suspension Rebuild, Elephant Racing Polybronze bearings? Suspension Bushings vs. Bearings, Opinions? Precision Needle Bearing Kits, who has Mueller's product installed... Suspension Bushings - Which ones? Best Bushings for my Application?, Oh noes! the choices! Are roller bearings really that great?, anyone out there with some experience? Whats the word on the self aligning control arm mounts, Do they help 914 Suspension Upgrade Spirited Street No Track?, What do you think?? Does anybody else besides me have trouble, getting keeping their NUTS tight!? trailing arm nuts Estimated time is 8 hours of removal, disassembly, bearing assembly, and installation for both sides given no problems with broken bolts or rust issues. Level of difficulty is 6 on a scale of 10. Tools and materials needed: -optional special tools -jack -good jack stands -17, 19, 22mm sockets -breaker bar -torque wrench rated up to 260 ft lbs -hammer -pickle fork or ball joint separator -Grease (Mobil 1 Synthetic, Swepco Wheel Bearing grease or Marine Grade Boat Trailer Wheel Bearing Grease) ![]() -Grease gun and cartridges -Gloves -Loctite 60905 ![]() -spray lubricant -degreaser and cleanser -spray paint (optional) Nomenclature: trailing arm = control arm control arm bearing = pivot bracket = cup bearing Housing = cad plated tube = bearing race body ear = tab (inner pivot) ![]() I had both Shine Racing (from a group buy) and Mueller's Design Werks rear bearings but used Mikes because he already sold me his last set and was also fitting the PMB v-calipers to my trailing arms. I sold the SRS rear bearings to (iamchappy) for his turbo 914. Jim (roadster fan) disassembled, powdercoated, and rebuilt these arms with new hub bearings and initially rubber bushings last year as a contribution to my neo914 project. FYI, I'm removing arms with Rich Johnson 5 lug hubs and I'm replacing them with arms I originally bought for my V8 914 on eBay. They are equipped with what appears to be 944 hubs to accept larger 944/911 CV's. At this time you may also consider upgrading to 5 lug. |
neo914-6 |
With trailing arms removed from car, now is a good time to inspect the suspension console, especially the inside
“tab” that the trailing arm axle attaches to, look for rust and also ensure that the through hole for the axle is in good condition and not “ovalized” ![]() Clean the area and check for rust or cracks. No damage but the surface appeared to be primer under the grease and dirt so I spray painted it. ![]() Trailing arm removed: ![]() Instructions on removing the rubber bushings and cross shaft You may want to powdercoat or spray paint the arms at this point |
Lo-Fi Version | Time is now: 29th April 2025 - 06:33 PM |
