BahnBrenner914 |
The girl is gone and all I have now is a beat-up teener ![]() ![]() Group: Members Posts: 301 Joined: 22-May 04 From: Gig Harbor and University Place, WA :: School in Angola, IN :: girlfriend in Sarasota, FL Member No.: 2,094 Region Association: None ![]() |
Took out the gas tank and it indeed is full of (IMG:style_emoticons/default/stromberg.gif) . I'll let the pics tell the rest:
Attached image(s) ![]() |
boxstr |
MEMBER:PACIFIC NORTHWEST REGION ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,522 Joined: 25-December 02 From: OREGON Member No.: 12 Region Association: Pacific Northwest ![]() |
I would hold off on filling the tank to the top. Fill part way then start the car and drive for a short distance then, If everything is tight and no leaks, fill the tank.
One thing I like to do when the tank is out, is move the pump and fuel filter to the side of the front trunk area, on th eearly 914s even on a 75-76 914. That way if you have to change the filter. You do not have to jack the car up. Trust that the jack stands will hold and slide under the car, loosen the hose clamps, gas dripping down, remove the old filter and gas dripping down, install the new filter and tighten the clamps. You can mount everything in a secure and safe place. CCLIN914NATION |
BahnBrenner914 |
I would hold off on filling the tank to the top. Fill part way then start the car and drive for a short distance then, If everything is tight and no leaks, fill the tank. Definately. I have the gear stack out right now, so I'm not putting anything in there yet. I'll probably put a gallon or two in of regular (see my poll/thread about gas grades) and see how that runs and adjust accordingly. |
Lo-Fi Version | Time is now: 28th June 2024 - 05:56 PM |
