OT: "Stop Leak" for water cooled engines?, How big of a hole will it plug? |
Eddie914 |
Jul 16 2007, 08:01 PM
Unregistered |
I think my daily driver BMW M5 has developed a water leak at the head gasket. I just barely limped home late last night and have not had the time to exactly pin-point the source.
I loses about one gallon of coolant every 10 miles. The leak is hardly noticeable at idle but at 3,000 rpm and 65 mph it does not take long for the low coolant light to come on and the temp to start rising ... especially in 95 degree heat. The last 100 miles after the leak started took quite a while! How big of a hole wil products like "BARS LEAK" plug? Cheap POS BMW! Can you believe the head gasket sprung a leak after only 309,000 miles? Thanks Eddie |
sww914 |
Jul 16 2007, 08:33 PM
Advanced Member Group: Members Posts: 2,439 Joined: 4-June 06 Member No.: 6,146 Region Association: None |
BTW, some purist engineer types will post telling you that you should never use a product like this, you should fix it properly, and they're completely correct. But you might not have a day and a half and several hundred dollars right now, so I say go for it and damn the consequences!
Lo-Fi Version | Time is now: 25th June 2024 - 10:28 PM |
