moneysmarts |
Member ![]() ![]() Group: Members Posts: 164 Joined: 2-March 04 From: Central Massachusetts Member No.: 1,745 Region Association: None ![]() ![]() |
I thought I had a bad injector on #3. With the motor is running, when I pull the lead to #1, #2, or #4, the engine stumbles as you would expect. If I remove the connector to cylinder 3, however, nothing happens. Even though I was getting a decent spray pattern when I pulled the injector out, I decided to replace the injector. Still nothing. There IS spark at the plug. And my noid light shows that there's electrical pulses at the connector lead. (IMG:style_emoticons/default/blink.gif) On the back of the block, under the air cleaner, I have three pairs of white wires that are solidly grounded.
Any ideas fellas? Thanks |
Dr Evil |
Send me your transmission! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,002 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region ![]() ![]() |
Coolio, the plug will tell...
Not switched wires if it just happened so that rules out some ideas. |
moneysmarts |
OK.
Plugs out. On the tan side, and dry as a bone...like no fuel. Checked the spray again... this time nothing. Tried another spare injector, still no gas. I'll swap in a known working injector (from one of the other cylinders) tonight. I can't believe I've got two bad injectors, though. Could the harness have a break in it. The noid light says there is power, though. Coolio, the plug will tell... Not switched wires if it just happened so that rules out some ideas. |
Lo-Fi Version | Time is now: 26th June 2024 - 06:29 AM |
