jus took my 914 v8 for inspection, and passed on hc 514 out of 600 |
jimkelly |
Jul 20 2007, 02:18 PM
Delaware USA Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
but failed on co's 6.84 out of 6.00.
nappa dude suggested i retard the dist 1/4 inch. also suggested maybe removing the air cleaner just for the emissions test. any comments?? jim |
drive-ability |
Jul 20 2007, 10:22 PM
Senior Member Group: Members Posts: 1,169 Joined: 18-March 05 From: Orange County, California Member No.: 3,782 |
Jim,
If you were to lean out the idle system a bit, team that with a 4 to 6 degree retarding of the timing. Doing that together may keep your HC from spiking. I assume you are doing an idle and cruse test? For the cruse portion I would install a new air-filter, make sure the choke plate is open all the way and you may be good to go. Your not far off, those readings and limits are insanely high compared to new cars. My guess is you take the place of around 300 new cars just with you V8 car, Ha Ha Ha isn't that great! (IMG:style_emoticons/default/aktion035.gif) |
jimkelly |
Jul 21 2007, 06:25 AM
the test is only at idle.
i am not changing engines but do wonder how well a brand new crate 350 from paceperformance would emissions wise with the right components?? http://paceperformance.com/index.asp?PageA...p;ProdID=154046 jim Jim, If you were to lean out the idle system a bit, team that with a 4 to 6 degree retarding of the timing. Doing that together may keep your HC from spiking. I assume you are doing an idle and cruse test? For the cruse portion I would install a new air-filter, make sure the choke plate is open all the way and you may be good to go. Your not far off, those readings and limits are insanely high compared to new cars. My guess is you take the place of around 300 new cars just with you V8 car, Ha Ha Ha isn't that great! (IMG:style_emoticons/default/aktion035.gif) |
Lo-Fi Version | Time is now: 27th September 2024 - 08:50 AM |
