My attempt to stop another source of oil leaks, I revised my oil filler. Have a look... |
URY914 |
Jul 30 2007, 12:55 PM
I built the lightest 914 in the history of mankind. Group: Members Posts: 123,041 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
During last weekend's autocross I had a problem with my oil filler cover coming off the “neck” of the engine case. I made the oil filler cover pictured below a few years ago because I didn’t like the stock tin piece and I wanted something with some bling. It never gave me a problem until last weekend but it did leak some oil once an awhile. The problem was the stock bale wire spring didn’t apply enough pressure on the gasket so give a good seal. I thought there must be something else I can do.
Attached thumbnail(s) |
URY914 |
Jul 30 2007, 01:06 PM
The new filler cover was made from a 1/4” piece of aluminum. I made it so it would cover the neck and by about 3/8” on the front and back sides and wide enough to be bolted to the angles. A hole was drilled for the dipstick. I used JB Weld to epoxy the filler funnel to the aluminum plate. The second picture below shows the gasket installed. A second piece of ¼” aluminum is used to locate the cover on the neck and holds the gasket in place.
Lo-Fi Version | Time is now: 28th September 2024 - 10:51 AM |
