Phoenix-MN |
Senior Member ![]() ![]() ![]() Group: Members Posts: 927 Joined: 23-January 04 From: ST. Bonifacius,MN Member No.: 1,590 ![]() |
I have finally mated the engine and transmission together and went through the put together - take apart, put together - take apart process about 5 times to get the throwout bearing free play where I wanted it, I started out with 1 washer under the pivot ball that was about .059" thick and this only had about 1/16" free play at the end of the clutch arm. I ground the washer down to .030" and this resulted in almost 1/2" free play (too much). After several variations I ended up with a washer that was .050" thick and gave me a little less than 1/4" free play. As you can surmise, it doesn't take much to make a large change in the free play movement.
Here's a picture of the assembled engine/transmission, I have a small issue to iron out with the drivers side header before it goes into the car. It's getting closer (but no light at the end of the tunnel yet) ![]() |
So.Cal.914 |
"...And it has a front trunk too." ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,588 Joined: 15-February 04 From: Low Desert, CA./ Hills of N.J. Member No.: 1,658 Region Association: None ![]() |
Couldn't you get the tape and plug wires to match your paint any closer?
Looks good... |
Lo-Fi Version | Time is now: 25th June 2024 - 04:51 PM |
