Phoenix-MN |
Senior Member ![]() ![]() ![]() Group: Members Posts: 927 Joined: 23-January 04 From: ST. Bonifacius,MN Member No.: 1,590 ![]() |
I have finally mated the engine and transmission together and went through the put together - take apart, put together - take apart process about 5 times to get the throwout bearing free play where I wanted it, I started out with 1 washer under the pivot ball that was about .059" thick and this only had about 1/16" free play at the end of the clutch arm. I ground the washer down to .030" and this resulted in almost 1/2" free play (too much). After several variations I ended up with a washer that was .050" thick and gave me a little less than 1/4" free play. As you can surmise, it doesn't take much to make a large change in the free play movement.
Here's a picture of the assembled engine/transmission, I have a small issue to iron out with the drivers side header before it goes into the car. It's getting closer (but no light at the end of the tunnel yet) ![]() |
JRust |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,309 Joined: 10-January 03 From: Corvallis Oregon Member No.: 129 Region Association: Pacific Northwest ![]() ![]() |
Hey Phillip, I remember your car from the meet I had at my pizza parlor in Monmouth years ago. That is one sweet ride you have. Good to know you are still around. Hopefully we will see each other at a meet again soon. Sorry to semi hijack the thread- Jamie
pjhaun |
Member ![]() ![]() Group: Members Posts: 370 Joined: 21-August 03 Member No.: 1,055 Region Association: None ![]() |
Hey Phillip, I remember your car from the meet I had at my pizza parlor in Monmouth years ago. That is one sweet ride you have. Good to know you are still around. Hopefully we will see each other at a meet again soon. Sorry to semi hijack the thread- Jamie Jamie, We had a great time. It's been a long time since we have been at any 914 get togethers. The car has been down for a couple of years . Hope to have the car running by the end of the year. Phillip |
Lo-Fi Version | Time is now: 25th June 2024 - 05:02 PM |
