Phoenix-MN |
Senior Member ![]() ![]() ![]() Group: Members Posts: 927 Joined: 23-January 04 From: ST. Bonifacius,MN Member No.: 1,590 ![]() |
I have finally mated the engine and transmission together and went through the put together - take apart, put together - take apart process about 5 times to get the throwout bearing free play where I wanted it, I started out with 1 washer under the pivot ball that was about .059" thick and this only had about 1/16" free play at the end of the clutch arm. I ground the washer down to .030" and this resulted in almost 1/2" free play (too much). After several variations I ended up with a washer that was .050" thick and gave me a little less than 1/4" free play. As you can surmise, it doesn't take much to make a large change in the free play movement.
Here's a picture of the assembled engine/transmission, I have a small issue to iron out with the drivers side header before it goes into the car. It's getting closer (but no light at the end of the tunnel yet) ![]() |
Phoenix-MN |
Phillip,
The ring is hand made from a 6" round by 1" thick aluminum round. I did it all with a drill press and hole saws. I am using 914 CV's and the ring fits them "snugly" and uses 2 set screws to hold it in place. The sensor is a Cherry magnetic reed switch MP200701. This drives a stock 78SC electronic speedometer. |
pjhaun |
Member ![]() ![]() Group: Members Posts: 370 Joined: 21-August 03 Member No.: 1,055 Region Association: None ![]() |
Phillip, The ring is hand made from a 6" round by 1" thick aluminum round. I did it all with a drill press and hole saws. I am using 914 CV's and the ring fits them "snugly" and uses 2 set screws to hold it in place. The sensor is a Cherry magnetic reed switch MP200701. This drives a stock 78SC electronic speedometer. So!!!, Paul!!!, Could I commission you to make one for me; to fit 911 CV? How much would it cost even with the magnetic switch? Thank You!!!! Phillip J. Haun Oak Harbor, WA. |
Lo-Fi Version | Time is now: 25th June 2024 - 05:07 PM |
