What Battery Is Best For A 914?, Please share your thoughts... |
kfieler |
Aug 6 2007, 01:56 PM
kfieler Group: Members Posts: 71 Joined: 26-July 07 From: Southern California (Mojave Desert) Member No.: 7,949 |
Okay... after sitting 10 years, this 1973 914 1.7 is cleaned-up, "prepped" and ready to be started! BUT FIRST I NEED A BATTERY! 1. I am considering an Optima "gel" battery, but don't know which one is going to work best for a car with "stock" battery tray and stock battery cables. Red top or Yellow top? Top post or side post? If you have an Optima, which one do you use? 2. What is the best way to mount an Optima battery to a stock battery tray? 3. I have never started the car and don't know if the engine is "junk" or not. Therefore, in your opinion, should I jump into an expensive (Optima) battery or first buy a cheap "Pep Boys Special" and replace the battery with a "gel cel" later if I decide to keep the project going? 4. Am I overlooking any other options (other than a cheap conventional or Optima battery)? I really appreciate any feedback you experts out there can provide! Thanks in advance for your input! - Keith |
anderssj |
Aug 7 2007, 03:49 PM
Dog is my copilot... Group: Members Posts: 1,667 Joined: 28-January 03 From: VA Member No.: 207 Region Association: MidAtlantic Region |
Just put another Optima 34R in my car--to replace the one I bought in 1992 (that one got moved to moved it to the 914 sitting at the shop).
I use a quick disconnect on the negative terminal, so there's no drain on the battery when the car is parked. COuld be part of the reason it lasted so long? Best, |
Lo-Fi Version | Time is now: 24th June 2024 - 07:30 AM |
