racunniff |
volt914 ![]() ![]() Group: Members Posts: 172 Joined: 21-August 06 From: Fort Collins, CO Member No.: 6,705 Region Association: Rocky Mountains ![]() |
Spent the day installing my windshield. Started with new windshield clips from Pelican Parts (you will need 19 of them):
![]() This picture shows the "top" and "bottom" of the clip. The "bottom" of the clip pushes into the windshield frame and also has the notch to capture the trim (see picture below for how this works). The "top" of the clip has the rivet that you'll need to drive in to permanently attach the clip. You'll also need some of this, Butyl Tape (I got mine at NAPA) - 1/4 inch is the recommended size: ![]() Note the warning about eye and skin irritation. I don't know if it's true, but I did the final cleaning and install wearing gloves, so I would not know. I do know that it is extremely sticky, and would likely be a lot of fun to get off your skin without evil chemicals like acetone. You'll also need these - window spacers (also available from Pelican Parts - you need 2): ![]() The butyl I bought also came with spacers, but they are not the same shape/size, so I do not trust them. Now for the clips. I dry-fit them on my trim to verify the orientation I wanted when I installed them: ![]() Installing the clips is pretty straightforward. You put a clip in a mounting hole: ![]() and then you push the clip in with your thumbs as far as you can: ![]() You need to get it very close to flush, because if you don't, when you try to push the rivet in, it will just pop the clip out of the hole (ask me how I know (IMG:style_emoticons/default/dry.gif) ). This is not fatal, though, because you can usually use a pair of pliers to pull the rivet back out and start over (assuming that you have not mashed the rivet as you try to push it in). Part II, coming soon. |
Gint |
Mike Ginter ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,096 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains ![]() ![]() |
We'll move this to the Lapuwali Classic Thread Forum in a few days. A And I'll have to make it a tech article when I get some time. We'll talk more about that later.
BTW , the trim is anodized, not chromed. Couple of questions: What is your name? Are you on our local email list? |
racunniff |
We'll move this to the Lapuwali Classic Thread Forum in a few days. A And I'll have to make it a tech article when I get some time. We'll talk more about that later. BTW , the trim is anodized, not chromed. Couple of questions: What is your name? Are you on our local email list? Anodized, chromed - regardless, too smooth to hold a paint coat (IMG:style_emoticons/default/laugh.gif) Thanks for the correction. PM sent with other info. |
Lo-Fi Version | Time is now: 3rd April 2025 - 05:21 AM |
