BKLA |
Really old member ![]() ![]() ![]() Group: Members Posts: 1,253 Joined: 14-August 05 From: OR Member No.: 4,590 Region Association: Pacific Northwest ![]() ![]() |
Unfortunately, "BluByU" sits most of the time at the CAMP, waiting to be driven. Last month, my son and I enjoyed a drive that took us out to the Portland historic races. We enjoyed the day and the track and left around 3:00 in order to make it back to my other son's soccer tournament. The six started and ran normally both two and from the race. Parked it at home and drove with the family to the game.
After family duties, when to start the six and....zzzzzzKKKK - no engagement. put the car in gear and rocked it back and forth. Tried again. This time engagement but loud clunk each rotation. ( the starter was relatively new so I thought maybe it was loose.) Drove up to the CAMP and parked it. Climbed under to see if the starter was "loose" - nope. Put the car cover on it and suspected a broken tooth on the ring gear. Called my trusty local independent Porsche mechanic and asked. Tried starting again same loud clunk - figured that it must have broken a couple of teeth. Anyway, had him check it and sure enough - broke 5 teeth in a row. Now here's the rub - He installed a new flywheel and a new starter (Bosch). THe six now starts sooo much quieter and faster than it ever did with the "high Torque" one. He told me that the high torque starters work great on high compression engines, but that he recommends the bosch starters for anything stock as they don't damage the ring gear. Now, the flywheel looks great and I understand that it can be machined and have a new ring gear welded on. (I saved it as well as the relatively new starter.) I have seen a number of flywheels with removable or replaceable ring gears and have been considering one for the new race 2.7 I have for "other" 914. Would it be worth it to have it machined for a replaceable ring gear as well as lightened and balanced? I would keep it as a back up for my 2.7 race motor -or- use it on the race motor. Waddya think? |
Dr Evil |
Send me your transmission! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,002 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region ![]() ![]() |
We need to settle this once and for all but getting a stock one, and the IMI one and powering the solinoid to see how far each projects. Then we will also have a measure for he space needed to use and can inform the vendor so he can start telling people.
BKLA |
We need to settle this once and for all but getting a stock one, and the IMI one and powering the solinoid to see how far each projects. Then we will also have a measure for he space needed to use and can inform the vendor so he can start telling people. Dr. Ev - I'll send you the hi torque starter if you really want to pursue it. F R E E It is about two years old and has had very little use. let me know where and when. |
Dr Evil |
We need to settle this once and for all but getting a stock one, and the IMI one and powering the solinoid to see how far each projects. Then we will also have a measure for he space needed to use and can inform the vendor so he can start telling people. Dr. Ev - I'll send you the hi torque starter if you really want to pursue it. F R E E It is about two years old and has had very little use. let me know where and when. I would take one just to test. I would even remove my starter to compare if anyone wants to foot the shipping. (kinda tight on funds, see other post (IMG:style_emoticons/default/dry.gif) ). I just think that this is awkward and want some definitive numbers to point to a reason. I would bet that I know I can get a stock bosch form my friends parts stash, I took a pic of it (IMG:style_emoticons/default/biggrin.gif) One thing I am noticing on your starters is that there is no blue insulated wire guide such as is on mine. |
BKLA |
We need to settle this once and for all but getting a stock one, and the IMI one and powering the solinoid to see how far each projects. Then we will also have a measure for he space needed to use and can inform the vendor so he can start telling people. Dr. Ev - I'll send you the hi torque starter if you really want to pursue it. F R E E It is about two years old and has had very little use. let me know where and when. I would take one just to test. I would even remove my starter to compare if anyone wants to foot the shipping. (kinda tight on funds, see other post (IMG:style_emoticons/default/dry.gif) ). I just think that this is awkward and want some definitive numbers to point to a reason. I would bet that I know I can get a stock bosch form my friends parts stash, I took a pic of it (IMG:style_emoticons/default/biggrin.gif) One thing I am noticing on your starters is that there is no blue insulated wire guide such as is on mine. Dr. Ev - I'll send it to you as I have no use for it. It'll go out later this week. (IMG:style_emoticons/default/biggrin.gif) I would be interested in understanding the spacing issue on the starters. I read tilton's installation instructions on the web. THey reference a very clear min. distance from the end of the starter gear to the ring gear as well as a way to measure it. I thought about McMarks spacing idea with washers, but it seems that the starter would work its way loose as it would want to pivot around the small surface area of the washers, over a period of time. Maybe not for those who tinker every weekend and would check it! (IMG:style_emoticons/default/biggrin.gif) Seems like a simple laser cut spacer would do the trick. I am really happy with the new flywheel and bosch starter. It is quieter and starts much quicker than before. Took off the GT/rally muffler and reinstalled the 911 sport muffler - drove it around a lot this weekend - quieter and can hear that wonderful weber music clearer- LOVE this car! |
Lo-Fi Version | Time is now: 25th June 2024 - 04:40 PM |
