LED Brake Lights on a 914, Anyone have any experience in this area? |
kfieler |
Aug 22 2007, 02:43 PM
kfieler Group: Members Posts: 71 Joined: 26-July 07 From: Southern California (Mojave Desert) Member No.: 7,949 |
I am getting ready to replace all the bulbs in a 1973 914 1.7; as many are bad or missing.
I have been contemplating the use of LED lights instead of incandescent bulbs. I have sourced the LED "bulbs", but don't want to put-out the extra bucks unless I have some assurance that they will work. My main concern is that LEDs may not be compatible with the 914's flasher relay. If I can "pop-in the bulbs and go", I'd like to use LEDs. However, if I need to make any modifications to the 914's electrical system (i.e. install an electronic flasher or load resistors), then all bets are off. Has anyone here converted the tail / parking / brake / signal lamps in a 914 over to LED? Are there any pitfalls to the process (or reasons why it should not be done)? (IMG:style_emoticons/default/screwy.gif) Thanks for helping a "newbie"! - Keith |
Brando |
Aug 22 2007, 02:56 PM
BUY MY SPARE KIDNEY!!! Group: Members Posts: 3,935 Joined: 29-August 04 From: Santa Ana, CA Member No.: 2,648 Region Association: Southern California |
The LED bulbs will not pull enough power to trigger the flasher relay. If you do just the rears they will flash much faster. If you do all 4 they will not flash at all. You will have to install an electronic flasher unit - basically a solid-state relay with a timing device. You can pick them up on the Evil Bay for roughly $30 shipped. Be sure to hook it up the right way, or it will blow (had a wiring mis-hap on my previous 944 and ate one).
You can put LED bulbs in the instruments without problems - just not the generator lamp. They just wont be dimmable... |
Lo-Fi Version | Time is now: 25th June 2024 - 12:51 AM |
