Another "taco plate" question, Update: job complete, but is gauge accurate? |
Cevan |
Aug 27 2007, 07:57 AM
Senior Member Group: Members Posts: 1,079 Joined: 11-December 06 From: Western Massachusetts Member No.: 7,351 |
I have '75 1.8 that the PO installed a nice center console complete with gauges. The volt meter works, clock didn't until I pulled it out and found the ground wire disconnnected. Now it keeps perfect time.
There is a plate currently where the oil temp sending unit goes. I also have a oil temp sending unit. I believe the order of installation is the red o-ring, the sending unit itself, the gasket and then black cover. I'm assuming I ground the black cover and the lead from the gauge goes to the sending unit. I can't seem to locate that wire. I'm assuming that the oil temp lead goes thru the center tunnel into the engine compartment. Where should I look? Will a ground wire also be with it? What color should the wires be? Brown=ground? |
Cevan |
Aug 27 2007, 08:43 AM
I was hoping there was a wire in the engine compartment. I'm trying to avoid pulling out the center console. The PO installed a Rennshifter and it looks like the only way to remove the console is to first remove the Rennshifter. I'm not sure how much readjusting is involved with re-installing the shifter.
If the gauge is already wired using the factory harness, then the lead wire must be somewhere. |
Lo-Fi Version | Time is now: 26th June 2024 - 01:48 AM |
