Cevan |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,079 Joined: 11-December 06 From: Western Massachusetts Member No.: 7,351 ![]() |
I have '75 1.8 that the PO installed a nice center console complete with gauges. The volt meter works, clock didn't until I pulled it out and found the ground wire disconnnected. Now it keeps perfect time.
There is a plate currently where the oil temp sending unit goes. I also have a oil temp sending unit. I believe the order of installation is the red o-ring, the sending unit itself, the gasket and then black cover. I'm assuming I ground the black cover and the lead from the gauge goes to the sending unit. I can't seem to locate that wire. I'm assuming that the oil temp lead goes thru the center tunnel into the engine compartment. Where should I look? Will a ground wire also be with it? What color should the wires be? Brown=ground? ![]() ![]() |
GTPatrick |
Member ![]() ![]() Group: Members Posts: 245 Joined: 8-September 05 From: Memphis, Tn. Member No.: 4,768 Region Association: None ![]() |
3 questions for y'all who are following this thread .
1 - Does anyone have a picture of the actual installation of the sending unit on the taco plate ? 2 - Does anyone have any pictures of the routing of the wireloom in the engine compartment from the firewall back to the sending unit ? (IMG:style_emoticons/default/blink.gif) 3 - Would it not be easier to route the wire from the indicator under the carpeting along the tunnel and drill a hole in thefireewall using a rubber grommet to allow the wire to pass thru it ? (IMG:style_emoticons/default/huh.gif) Thanks . (IMG:style_emoticons/default/beer.gif) |
Lo-Fi Version | Time is now: 26th June 2024 - 12:49 AM |
