nycchef |
mechanical moron ![]() ![]() ![]() Group: Members Posts: 952 Joined: 28-November 05 From: new york city n.y. Member No.: 5,202 Region Association: None ![]() |
heres the deal. when i turn the key (73 1.7) the starter will only turn intermittently, other times dead silence car has full power headlights,wipers radio, 12volts on the meter, i can hear the fuel pump, can push start it every time. is it just the ignition switch, which is original, loose and very flaky or am i in for an electrical gremlin adventure? (IMG:style_emoticons/default/stirthepot.gif)
por73914 |
I don't know what the hell I am doing... ![]() ![]() Group: Members Posts: 349 Joined: 10-April 07 From: Fayetteville, AR Member No.: 7,660 ![]() |
I connected the yellow wires together under the passenger seat and my problems were solved! I had the same problem. (IMG:style_emoticons/default/beerchug.gif)
SLITS |
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None ![]() ![]() |
I connected the yellow wires together under the passenger seat and my problems were solved! I had the same problem. (IMG:style_emoticons/default/beerchug.gif) The two big yellow wires were the starter interlock .... relay (under pass seat) wouldn't close to allow start when weight was in the seat unless seat belt was fastened .... yada yada .... thought it was a '74 only Federal thing to protect ourselves from ourselves. |
swl |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,409 Joined: 7-August 05 From: Kingston,On,Canada Member No.: 4,550 Region Association: Canada ![]() |
Lo-Fi Version | Time is now: 24th June 2024 - 11:43 PM |
