Eric_Shea |
PMB Performance ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 19,279 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains ![]() ![]() |
Confirmed: Tom has not bolted anything on to his car or drilled holes yet this week.
He did however give me a drawing for a fog light bracket with a 7/8" hole in the middle of it... there will be copious amounts of ribbing for that (IMG:style_emoticons/default/poke.gif) Now... get your @$$ off the computer before your wife sees you and breaks the rest of your fingers! (IMG:style_emoticons/default/w00t.gif) |
TJB/914 |
Mid-Engn. ![]() ![]() ![]() ![]() Group: Members Posts: 4,340 Joined: 24-February 03 From: Plymouth & Petoskey, MI Member No.: 346 Region Association: Upper MidWest ![]() ![]() |
Eric,
Wait a minute, don't drill that 7/8" hole in the rear panel. The yellow diachromate bracket with (2) smaller holes is ok to drill. These (2) holes attach the outside & inside bracket to the sheet metal. In the center of the 7/8" circle I just drilled a small hole in the rear panel to thread the wires through. If you need more info. call me on my cell (734) 834-5606 Tom BTW: I already drilled & mounted my rear fog lamp. I just have to wait till Jeff hopefully makes a wire harness for us accessory nut cases. Attached image(s) ![]() ![]() ![]() ![]() |
Lo-Fi Version | Time is now: 26th June 2024 - 08:05 AM |
